How Well Do TPE Floor Mats Hold Up in a 2015-2025 Ford F-150 SuperCab?
I picked up my 2018 F-150 SuperCab about three years ago, and like most people who buy these trucks, I intended to use it. Not just pavement pounding, but actual truck stuff—hauling materials, hitting job sites, taking it off-road when needed. The problem with actually using a truck is that the interior takes a beating faster than anything else.
The factory carpet in these aluminum-body F-150s is decent. It looks good when it's clean. But keeping it clean is another story entirely. After one winter of tracking in snow and road salt, I noticed the driver's side carpet starting to look matted down. Salt stains that wouldn't vacuum out. Little spots where water had soaked in and left marks.
I knew I needed better floor protection. Not the cheap universal mats that slide around, but something that would actually stand up to real use. After trying a couple options, I landed on a set of Trucktok 2015-2025 Ford F150 SuperCab All-Weather TPE Floor Mats that have completely changed how I think about interior protection.
Here's what I learned about keeping a newer F-150 clean without spending hours scrubbing carpets.
The Problem with Factory Carpet in a Truck You Actually Use
The 2015-2025 F-150s have nice interiors. Ford stepped up their game with materials, fit and finish, and overall quality. The carpet is thick and plush. It looks great in the showroom.
But carpet in a truck that sees real use has a short lifespan. Every time you get in with muddy boots, that dirt grinds into the fibers. Snow melts and soaks in before you even notice. Coffee spills, oil from equipment, dust from job sites—it all ends up ground into the carpet.
Once carpet is stained or worn, there's no good fix. You can clean it, but you'll never get it back to new. The fibers mat down permanently. The stains set in. And replacing carpet in these trucks is a massive job involving seat removal and hours of labor.
The smart move isn't trying to keep the carpet clean. It's keeping the carpet from getting dirty in the first place.
What Makes TPE Different from Rubber
Most people think of rubber when they think of heavy-duty floor mats. And rubber works, sort of. But it has some problems that become obvious over time.
Rubber mats smell. Leave your truck in the sun and come back to that chemical odor filling the cab. It's not harmful, but it's unpleasant.
Rubber gets stiff in cold weather. Try pulling out a frozen rubber mat sometime—it's like handling a sheet of plywood.
Rubber can crack and warp over time. Years of temperature cycles take their toll.
TPE—thermoplastic elastomer—solves all of that. It's a different class of material entirely.
There's no odor, even after hours in direct sun. It stays flexible whether it's below freezing or baking hot. It doesn't crack or warp with age. And it's lighter than rubber while being just as tough.
The Temperature Range Matters
These mats are designed to handle real-world conditions. From arctic cold to desert heat, they hold up.
In cold weather, they stay flexible. You can pull them out to clean them without them cracking or becoming brittle.
In heat, they don't get soft or develop that rubbery smell. They just sit there doing their job.
The material has a flexible memory too. If you fold or bend it during cleaning, it snaps back into shape instantly. No permanent creases, no deformation.
Why Tray-Style Walls Matter
One of the best features of these mats is the raised tray-style walls. This isn't just a flat mat with a slight lip—it's a deep tray designed to hold significant amounts of liquid and debris.
When you get in with snowy boots, the snow melts. With flat mats, that water runs off onto your carpet. With tray-style walls, it stays contained until you have a chance to clean it out.
Same thing with coffee spills or mud. The high walls keep everything inside the mat where it belongs. Your carpet stays dry and clean no matter what you track in.
The fluid holding capacity is substantial. You'd have to spill an awful lot to overflow these things.
How They Stay in Place
Safety is a real concern with floor mats. A mat that slides forward and gets under the pedals can cause an accident.
These mats are laser-scanned specifically for the SuperCab body style. Every contour matches the floor exactly. The transmission tunnel coverage is precise. The edges come up where they need to without interfering with anything.
The critical clearance zones around the gas and brake pedals are engineered into the design. No interference, no sliding, no worries.
The bottom of the mats has features that grip the carpet. They don't move around during normal driving, and they don't bunch up behind the pedals.
What About Cleaning
This is the feature that sells most people. When these mats get dirty, you pull them out and hose them off.
Mud rinses away instantly. Salt dissolves and disappears. Coffee, oil, whatever—it all comes off with water.
Let them drip dry for a few minutes and put them back in. They look brand new every time.
No scrubbing, no special cleaners, no hauling them to the car wash. Just a hose and a few seconds.
The material is naturally non-stick, so nothing really bonds to it. Even dried-on mud usually just flakes off with a quick rinse.
The SuperCab Specifics
These mats are made specifically for the SuperCab, also called Extended Cab. That's the body style with two full-size doors up front and two smaller rear-hinged doors in back. It has a smaller back seat area than the SuperCrew.
They will not fit the SuperCrew Cab, which has four full-size doors and a larger back seat with a different floor shape.
They also won't fit trucks without factory carpet—some work truck trims have vinyl floors that require different mats.
If you've got a 2015-2025 F-150 SuperCab with factory carpet, these are made for your truck.
What You Get
The set includes three pieces. Two for the front row—driver and passenger. One for the second row that covers the back floor area.
The front mats have those deep tray walls to contain whatever you track in. Mud, snow, water, salt—it all stays in the mat instead of running onto the carpet.
The rear mat is one continuous piece that protects the whole back area. If you've got passengers, kids, dogs, or just use the back for storage, this keeps everything contained.
The Material Advantages
TPE is eco-friendly and completely free of toxic fumes. Even after hours in the sun, there's no off-gassing, no chemical smell, nothing.
The extra-thick material is engineered specifically for heavy-duty work boots. It won't wear through where your heel rests, even after years of use.
The surface is naturally non-stick. Oil and coffee wipe away with one swipe. Water and mud bead up instead of spreading.
How They Hold Up Long-Term
I've had TPE mats in my truck for about a year and a half now. They've been through mud, snow, salt, sand, and plenty of spills.
They still look new. No warping, no cracking, no fading. The edges haven't curled. The surface hasn't worn smooth where my heel rests.
The truck has been through temperatures from single digits to triple digits. The mats have taken everything without complaint.
The Resale Value Factor
Here's something I hadn't thought about until recently. Keeping the original carpets in pristine condition matters when it comes time to sell or trade.
A truck with stained, worn carpet looks older than it is. It feels neglected. Buyers notice.
With good mats protecting the factory carpet, you can pull them out at trade-in time and reveal carpet that still looks new. That's a real selling point.
These mats aren't just protecting your interior—they're protecting your investment.
Final Thoughts
The 2015-2025 F-150 is a great truck. It's comfortable, capable, and packed with features. But like any truck, the interior takes abuse every time you drive.
TPE floor mats are the smartest protection you can add. They fit perfectly, stay put, clean instantly, and last for years. No smell, no warping, no sliding. Just solid protection that makes using your truck easier.
The tray-style walls contain spills and snow. The extra-thick material stands up to work boots. The easy cleaning means you spend less time maintaining and more time using.
If you're tired of fighting mud and salt in your F-150, these mats are worth a look. They make a difference you'll notice every time you open the door.
*If you've got an F-150 SuperCab, what do you use to protect the interior? Drop your experience below.*
