The HO Cummins: Does it really need more frequent service?
DieselWright
I’m running the HO version with the Aisin transmission. I see guys with the standard output (SO) trucks pushing their oil changes to 10k-15k miles. Should HO owners be more conservative, or is the engine internals stout enough that it doesn't matter?
The HO injectors run higher pressures, and you get more fuel dilution than the SO version. I'd never push HO oil past 7500 miles, especially if you tow heavy.
The HO engine is demanding on the cooling system. Keep your intercooler and radiator clean; it’s vital for maintaining low EGTs under high torque.
