What Happens When You Fix the L5P's CCV Design? Cleaner Intakes, Cooler Air, and Permanent Hardware
The 2017-2023 L5P Duramax represents GM's most advanced light-duty diesel architecture to date. Its 6.6-liter displacement, advanced fuel system, and electronically controlled variable-geometry turbocharger deliver class-leading power and torque. But beneath the polished valve covers and intricate intake plumbing lies a system that, by design, introduces a persistent contaminant into one of the most critical areas of your engine: the CCV system.
Understanding why this matters requires looking beyond the marketing materials and examining the actual engineering principles at work—and where those principles create unintended consequences for long-term engine health.
Part 1: The Physics of Crankcase Ventilation and Bernoulli's Principle​
Every internal combustion engine produces blow-by. It's an unavoidable consequence of the physics of combustion. Despite the best efforts of piston ring engineering, a small percentage of combustion pressure and unburned gases inevitably slip past the rings and enter the crankcase. These gases must be evacuated; if they accumulate, they'll pressurize the crankcase, forcing oil past seals and gaskets.
The L5P's factory solution: A closed crankcase ventilation system that uses Bernoulli's principle to draw these gases out of the engine. The intake air horn is specifically shaped to create a low-pressure zone—essentially a vacuum—that pulls crankcase vapors from the valve cover, through the CCV system, and directly into the turbocharger inlet.
The engineering intent: This is elegant in theory. It requires no moving parts, no electrical power, and it ensures that crankcase emissions are reburned rather than vented to atmosphere. It meets EPA requirements while appearing mechanically simple.
The mechanical reality: That vacuum doesn't discriminate. It pulls not only combustion gases but also a continuous aerosol of atomized engine oil. And it pulls this oil-laden air directly into the path of a compressor wheel spinning at speeds exceeding 100,000 RPM.
Part 2: The L5P-Specific Design Flaws​
The Plastic Problem
The factory L5P CCV system incorporates plastic components that are, frankly, not designed for permanent service in the environment they inhabit. Underhood temperatures, continuous exposure to oil vapor, and the thermal cycling that occurs every time the engine runs and cools combine to make plastic a questionable material choice for this application.
The product information notes that the factory system is "prone to failure due to plastic cracking over time." This isn't theoretical. Multiple high-mileage L5P inspections have revealed CCV housings that have become brittle and developed stress cracks, creating vacuum leaks that affect crankcase evacuation and, in some cases, allow unmetered air into the intake system.
The Oil Ingestion Problem
Here's the more insidious issue: the factory CCV system routes oil vapor directly into the turbo inlet. That oil doesn't just disappear. It follows a predictable path of contamination:
  • Turbocharger compressor wheel fouling: Oil deposits on the compressor blades create an uneven surface that disrupts airflow and reduces compressor efficiency. Over time, this manifests as slower spool times and reduced boost response.
  • Intercooler contamination: The oil vapor travels through the charge air system and condenses in the intercooler, coating the internal surfaces. Oil acts as an insulator, reducing the intercooler's ability to transfer heat and leading to elevated intake air temperatures.
  • Charge air boot degradation: Silicone and rubber components exposed to continuous oil vapor soften and deteriorate, becoming more susceptible to blow-off under boost pressure.
The Bernoulli Principle Paradox
The factory system's reliance on Bernoulli's principle to create vacuum in the intake air horn introduces another complication: it pulls crankcase vapors regardless of engine load or operating condition. During high-boost, high-temperature operation, that means hot, oil-laden air is being introduced directly into the intake stream, raising the thermal load on the charge air system and contributing to elevated intake temperatures.
Part 3: Why the L5P's Design Differs from Previous Generations​
The L5P represents a significant departure from earlier Duramax CCV layouts. The oil fill location was moved, and the CCV system was integrated differently than on the LML or LMM platforms. This creates both challenges and opportunities.
The oil fill safety concern: The product information notes that the kit "separates the CCV system from the oil fill port for safety reasons." This is a subtle but important point. In the factory configuration, the CCV system and oil fill are interconnected. A mis-timed oil fill or a failure in the CCV system can potentially allow crankcase pressure to vent through the oil fill, which is not an ideal situation from a safety or operational standpoint.
The front-mounted oil fill advantage: The relocation of the oil fill to the front of the motor in the modified configuration isn't just about convenience—it's about creating physical separation between the crankcase ventilation path and the point where you interact with the engine during maintenance.
Part 4: The Technical Solution – Integrated Differential Drop Devices​
The TruckTok L5P CCV Reroute/Delete Kit addresses the fundamental deficiencies of the factory design through several engineering improvements, the most significant being the integrated differential drop devices.
How they work:
These are precisely machined features within the billet aluminum CCV block that create pressure differentials, encouraging oil droplets to coalesce and drop out of the vapor stream before they can enter the intake. This is passive separation—no moving parts, no filters to replace, no maintenance required.
The principle: As the oil-laden vapor flows through the CCV block, it encounters these carefully designed geometries. The changes in flow direction and velocity cause heavier oil particles to separate from the lighter air stream. The separated oil drains back toward the crankcase, while the cleaned vapor continues toward the intake (or, in a reroute configuration, toward atmosphere).
The result: Significantly reduced oil ingestion into the turbocharger and charge air system without introducing restrictive baffles or serviceable filter elements that would require regular maintenance.
Part 5: Material Science – Why Aluminum Matters​
The factory plastic CCV components are manufactured to a price point. They're adequate for the warranty period. They are not designed for indefinite service in an environment characterized by heat, vibration, and chemical exposure.
Aluminum alloy construction offers several advantages that directly address the factory system's weaknesses:
  • Thermal stability: Aluminum handles underhood temperature extremes without becoming brittle or deforming. It expands and contracts at rates compatible with other engine components.
  • Chemical resistance: Unlike plastic, which can be degraded by long-term exposure to oil additives and combustion byproducts, aluminum is essentially inert in this environment.
  • Structural integrity: The kit components are machined from billet aluminum, meaning they're solid metal, not cast or molded. This eliminates the possibility of stress cracks developing at mold lines or thin sections.
  • Permanent installation: The black anodized finish provides corrosion resistance and ensures that the components will look and function as intended for the life of the truck.
Part 6: The Thermodynamic Benefit – Keeping Hot Air Out of Your Intake​
The product description mentions preventing "high-temperature charge air from the turbo enter the intake air horn through the factory CCV system." This requires some unpacking.
In the factory configuration, the CCV system draws crankcase vapors into the intake air horn—which is precisely the point where air is entering the turbocharger. During high-load operation, that air horn sees elevated temperatures from underhood heat soak and from the proximity to the turbocharger itself.
By rerouting the CCV system, you accomplish two thermodynamic objectives:
  1. You eliminate the introduction of hot crankcase vapors into the intake stream. The air entering your turbo is cleaner and cooler than it would be otherwise.
  2. You prevent the recirculation of heated air. In the factory setup, the CCV system can create a feedback loop where hot air from the turbo area is drawn back into the intake, raising inlet temperatures.
The result is a measurable reduction in intake air temperatures, which translates directly to denser air charges and more efficient combustion.
Part 7: What the TruckTok Kit Actually Includes​
The TruckTok 2017-2024 L5P Duramax CCV Reroute/Delete Kit is engineered as a complete solution:
  • Billet aluminum CCV block: Machined from solid stock with integrated differential drop devices for passive oil separation. Black anodized for corrosion resistance.
  • High-temperature hoses: Constructed from materials specifically selected for oil resistance and thermal stability. These aren't generic vacuum lines; they're engineered for this application.
  • Precision mounting hardware: All necessary fasteners are included, ensuring proper fitment and sealing.
  • Relocated oil fill provision: The kit provides a more convenient and safer oil fill location at the front of the motor, physically separating the CCV system from the fill point.
What it eliminates: The factory plastic CCV housing, the problematic oil fill integration, and the path for oil vapor to enter the turbo inlet.
What it preserves: Proper crankcase evacuation, ensuring that internal pressures remain within specifications and that seals and gaskets aren't stressed by pressure buildup.
Part 8: The Installation Philosophy – No Maintenance, Permanent Solution​
One of the most compelling aspects of this kit is its maintenance-free design. Unlike catch cans that require periodic emptying or filter elements that need replacement, the integrated differential drop devices require no ongoing attention. They simply work, passively, for the life of the engine.
This is the engineering difference between a band-aid and a permanent solution. A catch can manages symptoms; it collects oil that has already entered the intake stream, but it requires you to remember to empty it, and if you forget, it becomes a restriction. The TruckTok approach prevents oil from entering the intake in the first place, using physics rather than maintenance to achieve the result.
The L5P Duramax is an exceptional engine. Its core architecture—the block, rotating assembly, fuel system, and turbocharger—represents some of the best engineering GM has ever produced. But the factory CCV system introduces compromises that, over time, affect performance and component longevity.
For the owner who views their L5P as a long-term asset and understands the physics of oil contamination, this kit represents a mechanically sound investment. It doesn't add horsepower in the traditional sense—it preserves the horsepower and efficiency that the engine was designed to produce by preventing the slow, cumulative degradation caused by oil ingestion.
If you've inspected your L5P's intercooler pipes and found oil, or if you've noticed slower turbo response over time, the CCV system is the likely culprit. What has your experience been with intake contamination on your L5P? Drop your observations below.
