What's the Best Winter Floor Mat for a 2014-2019 Chevy Crew Cab? TPE Reviewed
I bought my 2015 Silverado 2500HD Crew Cab about three years ago, and it's been my go-to for everything since. Hauling a gooseneck trailer, running to job sites, taking the family on camping trips—these K2XX trucks do it all. They're comfortable, powerful, and just nice to be in.
But there's one problem I kept running into. The carpet.
These trucks have a ton of floor space. The Crew Cab gives you room for actual adults in the back, which is great. But that also means a whole lot of carpet to protect. And if you actually use your truck like a truck, that carpet takes a beating.
I tried a few different floor mat options over the years. Some were cheap. Some were expensive. Most just didn't work the way I wanted. Then I found a set from TruckTok that finally solved the problem.
The Carpet Problem Nobody Talks About
The GMT900 trucks have decent interiors, but the carpet is still carpet. It absorbs everything.
Mud gets ground into the fibers the first time you get in with dirty boots. Snow melts and soaks in before you even notice. Road salt leaves white stains that never fully come out. Coffee spills become permanent artwork on your floorboards.
Once that happens, there's no fixing it. You can scrub, you can shampoo, but you'll never get it back to new. The fibers mat down. The stains set. And replacing carpet in a Crew Cab means pulling seats, removing trim, and spending a whole weekend on a job nobody enjoys.
The solution isn't better cleaning. It's better prevention.
Why I Switched to TPE
I'd always used rubber mats before. They're everywhere, they're cheap, and they sort of work. But rubber has some real problems that you only notice after using them for a while.
Rubber mats smell. On a hot summer day when your truck has been sitting in the sun, that chemical odor fills the whole cab. After a few hours of driving, it gets old fast.
Rubber gets stiff when it's cold. Try pulling out a frozen rubber mat sometime—it's like handling a sheet of plywood. And they crack over time. A few years of temperature cycles and they start looking rough.
TPE is different. There's no smell at all, even when the truck has been baking in the sun all afternoon. It stays flexible whether it's below freezing or hot enough to fry an egg on the hood. It doesn't crack or warp. And it's lighter than rubber while being just as tough.
The TruckTok mats I installed are made from high-density TPE that's engineered to outlast standard rubber. No warping, no cracking, no odor.
Why These Fit Different
The K2XX trucks have a specific floor shape. The transmission tunnel, the footwells, the rear floor—everything is molded a certain way. Universal mats just don't work. They slide around, leave gaps, and never quite cover everything.
These TruckTok mats are laser-scanned specifically for these trucks. Every contour matches exactly. The transmission tunnel is perfectly hugged. The edges come up where they need to without interfering with anything.
They snap right into the factory retention posts too. Once they're in, they're not going anywhere. No sliding forward under the pedals, no bunching up behind your feet. Just solid, secure coverage that stays put even on rough terrain.
The High-Wall Design
One thing I really appreciate about these mats is the raised edges. This isn't just a flat mat with a tiny lip—it's a deep tray designed to actually contain stuff.
When you get in with snowy boots, the snow melts. With flat mats, that water runs right off onto your carpet. With these high walls, it stays contained until you have a chance to clean it out.
Same thing with mud, coffee spills, or whatever else ends up on your floor. Everything stays in the mat where it belongs. Your carpet stays dry and clean.
The Cleaning Factor
Here's the thing that sold me on these. When they get dirty—and they will—you just pull them out and hose them off. That's it.
Mud rinses away instantly. Salt dissolves and disappears. Coffee, oil, whatever—it all comes off with water. Five seconds with a hose and they look brand new.
Let them drip dry for a few minutes and put them back in. No scrubbing, no special cleaners, no hauling them to the car wash. Just water and a few seconds.
The material has a flexible memory too. If you fold it during cleaning, it snaps right back to its original shape. No permanent creases.
What About Heat and Cold
These trucks see all kinds of weather. Cold winters, hot summers, everything in between. Floor mats need to handle that.
The TruckTok mats stay flexible from arctic cold to desert heat. No cracking when it's freezing. No getting soft and mushy when it's hot. They just do their job regardless of the temperature.
The Crew Cab Coverage
You get three pieces total. Two for the front—driver and passenger. One massive piece for the back seat that covers the whole rear floor area.
The front mats have those raised edges to contain whatever you track in. Mud, snow, water, salt—it all stays in the mat.
The rear mat is one continuous piece. If you've got kids, dogs, or just use the back for gear, this is a lifesaver. Everything that happens back there lands on the mat, not your carpet. No gaps, no dirt sneaking through.
Which Trucks These Fit
These are specifically for Crew Cab trucks. Here's the breakdown:
  • 2014-2018 Silverado/Sierra 1500 Crew Cab
  • 2015-2019 Silverado/Sierra 2500HD and 3500HD Crew Cab
They won't fit Regular Cab or Extended Cab trucks. The floor shape is completely different. Make sure you've got the right cab configuration before ordering.
The Long-Term Value
Good floor mats aren't cheap, but cheap floor mats aren't good. I learned that lesson the hard way.
These mats will outlast your truck. No cracking, no warping, no fading. The high-density TPE is thicker than standard rubber and built for years of abuse.
And when you eventually sell the truck, you can pull these mats out and reveal carpet that still looks new. That's real value when it comes time to trade or sell.
Final Thoughts
The 2014-2019 Silverados and Sierras are some of the best trucks Chevy and GMC have ever made. They're comfortable, capable, and still holding up strong. Keeping the interior clean is one of the best ways to preserve them.
The TruckTok TPE floor mats are the simplest solution I've found. They fit perfectly, clean instantly, and last forever. No smell, no sliding, no staining. Just solid protection that works.
If you're tired of fighting mud and salt in your Crew Cab, these mats are worth a look.
What do you use to protect your K2XX interior? Drop your experience below.
