If you're reading this, you probably spend your days around heavy trucks. Maybe you own a Peterbilt or Kenworth. Maybe you're fleet manager for a company running Volvo or Freightliner. Or maybe you're an owner-operator who's learned that the emissions equipment on modern diesels can be a source of endless frustration and expense.
The Cummins ISX 15 is one of the most common heavy-duty diesel engines on the road. It's found in nearly every make of Class 8 truck, and for good reason—it's a robust, powerful platform when properly maintained. But like every modern diesel, it carries emissions equipment that introduces compromises.
The EGR system on the ISX is particularly complex. It's designed to reduce NOx emissions by recirculating exhaust gas back into the intake, but that process comes with real costs. Heat, soot, and wear are the trade-offs for cleaner emissions.
I've spent time around these engines, both in my own truck and helping friends with theirs. When the opportunity came to work with the TruckTok Stage 2 EGR Delete Kit for the CM2250 and CM2350 engines, I wanted to understand what it actually does and whether it makes sense for owners running these trucks. Here's what I learned.
How it works: The system taps exhaust gas from the manifold, routes it through an EGR cooler to reduce temperature, then reintroduces it into the intake stream. This dilutes the incoming air, lowering combustion temperatures and reducing NOx formation.
The dual-cooler setup: Many ISX engines use a two-stage cooling system for the EGR. The gas passes through an initial cooler, then through a second stage before entering the intake. This is effective at cooling, but it doubles the potential failure points.
The control system: The CM2250 and CM2350 ECMs actively monitor EGR operation—flow rates, temperatures, valve position. They're sophisticated systems designed to keep emissions in check, but they're also sensitive to any deviation from expected parameters.
Cooler failure: EGR coolers on the ISX can and do fail. They're subject to extreme thermal cycling—from cold start to 1,000°F+ exhaust temperatures and back again. Over time, this stress can cause cracking at the tube sheets or within the cooler core. When a cooler fails, coolant can enter the exhaust stream or, worse, the intake.
Soot buildup: The recirculated exhaust carries particulate matter. That soot deposits in the intake manifold, on the valves, and in the EGR valve itself. Over time, this buildup restricts airflow and can cause the EGR valve to stick or fail to seal properly.
The heat load: The EGR cooler dumps exhaust heat into the engine coolant. That's heat the cooling system has to manage on top of the engine's own thermal load. In a heavy-duty truck already working hard, that additional heat can push cooling systems closer to their limits.
Maintenance burden: EGR systems require maintenance. Valves need cleaning, coolers need inspection, and when they fail, the repair costs are substantial—especially considering the labor involved in accessing these components on a Class 8 truck.
The plates: Four precision-cut plates form the core of the kit. Two are made from 6061 aircraft-grade billet aluminum, CNC machined and anodized for durability and corrosion resistance. These block off the intake and exhaust ports where the EGR system connected. The other two plates are 304 stainless steel—they'll never rust, even in the harsh environment of a heavy-duty truck engine bay.
The plug fittings: Five stainless steel plug fittings seal various ports in the cooling system and exhaust. Like the plates, these are 304 stainless—permanent, corrosion-resistant, and designed to handle high pressures.
The gasket: A high-temperature resistant graphite gasket ensures a perfect seal between components. Graphite is the right choice for this application—it handles extreme temperatures without degrading and maintains sealing pressure through thermal cycles.
The materials: The combination of 6061 aluminum and 304 stainless steel covers all the bases. Aluminum is lightweight, thermally conductive, and corrosion-resistant. Stainless steel offers maximum durability where it's needed. Both materials are chosen to outlast the engine.
Cooler intake air: With no hot exhaust gas being recirculated, the air entering the engine is significantly cooler. Cooler air is denser, which means more oxygen for combustion. That translates to more complete burning and better efficiency.
Cleaner intake tract: Without soot-laden exhaust flowing through the intake, carbon buildup is eliminated. The intake manifold, valves, and turbo inlet stay clean, maintaining airflow and performance over the long term.
Reduced cooling system load: The EGR cooler is no longer dumping exhaust heat into the coolant. That means the cooling system can focus entirely on managing engine heat rather than dealing with waste heat from emissions equipment.
Elimination of failure points: The EGR cooler and valve are complex components with moving parts and exposure to extreme conditions. Removing them eliminates the possibility of failure entirely. No cracked cooler, no stuck valve, no coolant in the intake.
Simplified maintenance: With the EGR system gone, there's one less thing to inspect, clean, or repair. For trucks that run hundreds of thousands of miles, that simplification adds up over time.
The kit includes everything needed—plates, gasket, plug fittings—but installation requires mechanical competence and the right tools. This is not a driveway job for a beginner. It's work best done by someone familiar with these engines.
The payoff is permanent. Once the EGR system is removed, it's gone. No more worrying about cooler failure, no more carbon buildup, no more EGR-related maintenance.
A proper delete tune is required to:
Removing emissions equipment from a vehicle operated on public roads violates the Clean Air Act. For trucks used in off-road applications—construction, mining, agriculture, competition—this kit is appropriate. For trucks that ever touch public highways, it's not legal.
Anyone considering this modification needs to understand and accept that reality. The fines for tampering with emissions equipment can be substantial, and enforcement is real.
The TruckTok Stage 2 EGR Delete Kit addresses these issues directly. It replaces the problematic EGR valve and cooler with precision-machined plates and plugs made from 6061 aluminum and 304 stainless steel. A high-temperature graphite gasket ensures leak-free operation.
For trucks used in off-road applications where emissions compliance isn't required, this kit offers several real benefits:
For owner-operators and fleet managers looking to improve the reliability and efficiency of their ISX-powered trucks in off-road applications, this kit represents a permanent solution to a persistent problem.
If you've deleted the EGR on an ISX 15, what was your experience? Drop your thoughts below.
Part 1: Understanding the ISX EGR System
The EGR system on the ISX 15 is more complex than what you'll find on light-duty diesels. These engines are designed to run hundreds of thousands of miles under heavy load, and the emissions equipment has to keep up.How it works: The system taps exhaust gas from the manifold, routes it through an EGR cooler to reduce temperature, then reintroduces it into the intake stream. This dilutes the incoming air, lowering combustion temperatures and reducing NOx formation.
Part 2: The Real-World Problems with EGR on the ISX
After years of working on these engines, here's what I've observed about the EGR system's weak points.Cooler failure: EGR coolers on the ISX can and do fail. They're subject to extreme thermal cycling—from cold start to 1,000°F+ exhaust temperatures and back again. Over time, this stress can cause cracking at the tube sheets or within the cooler core. When a cooler fails, coolant can enter the exhaust stream or, worse, the intake.
Part 3: What the TruckTok Stage 2 Kit Actually Does
The TruckTok EGR delete kit is designed for the CM2250 and CM2350 engines found in 2010-present ISX 15 trucks. Here's what's included and why each component matters.The plates: Four precision-cut plates form the core of the kit. Two are made from 6061 aircraft-grade billet aluminum, CNC machined and anodized for durability and corrosion resistance. These block off the intake and exhaust ports where the EGR system connected. The other two plates are 304 stainless steel—they'll never rust, even in the harsh environment of a heavy-duty truck engine bay.
Part 4: What You Gain by Removing the EGR System
For trucks that are used off-road or in applications where emissions compliance isn't a factor, EGR deletion offers several real benefits.Cooler intake air: With no hot exhaust gas being recirculated, the air entering the engine is significantly cooler. Cooler air is denser, which means more oxygen for combustion. That translates to more complete burning and better efficiency.
Part 5: The Installation Reality
Installing an EGR delete on an ISX 15 is not a small job. These are heavy-duty trucks with tightly packed engine bays, and accessing the EGR components requires significant disassembly.The kit includes everything needed—plates, gasket, plug fittings—but installation requires mechanical competence and the right tools. This is not a driveway job for a beginner. It's work best done by someone familiar with these engines.
Part 6: The Tuning Requirement
As with any modern diesel, removing the EGR hardware requires corresponding software changes. The CM2250 and CM2350 ECMs are programmed to monitor EGR operation—valve position, flow rates, temperatures. When they detect that the system is missing, they'll set codes and may derate power.A proper delete tune is required to:
- Disable EGR monitoring
- Eliminate fault codes
- Optimize fuel delivery for the new airflow characteristics
Part 7: The Off-Road Designation
The product description includes a clear statement: "For off-road use only!" This is not casual language—it's a legal requirement.Removing emissions equipment from a vehicle operated on public roads violates the Clean Air Act. For trucks used in off-road applications—construction, mining, agriculture, competition—this kit is appropriate. For trucks that ever touch public highways, it's not legal.
Part 8: The Verdict
The 2010-present Cummins ISX 15 is a workhorse engine that powers thousands of heavy trucks across North America. Its EGR system, while effective at reducing NOx emissions, introduces heat, soot, and potential failure points that affect long-term reliability.The TruckTok Stage 2 EGR Delete Kit addresses these issues directly. It replaces the problematic EGR valve and cooler with precision-machined plates and plugs made from 6061 aluminum and 304 stainless steel. A high-temperature graphite gasket ensures leak-free operation.
- Cooler intake air for better combustion
- Cleaner intake tract with no carbon buildup
- Reduced load on the cooling system
- Elimination of EGR-related failure points
- Simplified long-term maintenance
