This is the installation process for the TH-0025: 2" Receiver Hitch Ball Mount with 6,000 lbs GTW & Hitch Pin, for your reference during the installation process.
Insert the square connector. Insert the black square steel rod of the ball connector into the 2-inch trailer receiver at the rear of the vehicle.
Pass the matching silver locking pin through the aligned hole. Insert the R-shaped spring pin at the other end of the locking pin. Ensure the pin is fully engaged in the slot to prevent slippage during driving.
Reverse so that the trailer ball is directly under the trailer coupler. Lower the trailer connector and lock the safety latch.
