This is the installation process for the ER-0072: 2007-2024 6.7L Dodge Ram Cummins EGR Throttle Valve Delete Kit,provided for your reference during installation.
ER-0072
Step1:
1.Use a wrench or socket to remove the connector and heat shield.
2.Release the clamp of the intercooler tube and separate boot.
Remove four 8mm bolts and disconnect the valve, with two screws hidden below.
1.Install the throttle delete valve bolt and four hexagonal bolts with washers in the installation kit.
2.Reconnect and tighten the intercooler tubes and clamps.
1.Reinstall the heat shield and connector.
2.Fixed unused throttle valve connection.
2009-2019 6.7L Dodge Ram Cummins Coolant Bypass Barb Leak repair Adapter Kit
2007-2018 6.7L Dodge RAM 2500 3500 Cummins Diesel 3.5inch High Flow Intake Manifold Elbow Tube Horn
2007-2009 6.7L Dodge Ram Cummins Diesel EGR Delete Kit
2010-2012 6.7 Dodge Ram Cummins 4" Turbo-Back DPF Delete Pipe
2007.5-2012 6.7L Dodge Ram Cummins 2500/3500 4" DPF Delete Race Pipe
2007.5-2018 6.7L Dodge Cummins 2500 3500 CCV Black Crankcase Ventilation Diesel
2007.5-2012 6.7L Dodge Ram Cold Air Intake w/Filter
2013-2018 6.7L Ram Cummins Diesel EGR Cooler Throttle Valve Delete Kit
2013-2018 6.7L Ram Cummins 5" Turbo Back DPF Delete Pipe (With Muffler )
2013-2018 6.7L Dodge Ram Cummins 4" Downpipe back DPF Delete Pipe
2013-2018 6.7L Ram 2500 3500 Turbo Diesel 4" Exhaust Tube Pipe Kit
