This is the installation process for the ER-0298: 2015-2019 6.7L Ford Powerstroke SOTF Switch w/Connector, provided for your reference during installation.
ER-0298
First, open the truck's hood. It is recommended to disconnect the negative terminals of both power sources.
Locate the fuel temperature sensor and disconnect it from its wiring harness.
On the left side of the driver's side step in the cab, cut a small slit in the rubber gasket. Be careful not to damage any wires in the wiring harness.
Use a steel or iron wire to pass through the firewall from the rubber gasket, and secure the end of the switch wire to the end of the steel or iron wire with tape. Pull the switch wire into the engine compartment.
Draw the switch wire correctly to the sensor location and wrap the switch wire with the flexible sleeve provided in the kit.
Assemble the provided connectors and install the switch harness onto the connectors, ensuring the mounting holes match the green and green/white wires on the original harness. Polarity is irrelevant. Seal the three unused holes using the provided plugs.
Insert the new switch connector into the fuel temperature sensor wiring harness, and then wrap the other original sensor with tape to prevent corrosion.
Find a suitable location to drill a hole and install the switch. This may vary depending on the truck and individual operating habits.
After installing the switch, bundle and organize the switch wiring harness and other wiring harnesses below the dashboard.
2011-2023 6.7L Ford Powerstroke Diesel EGR Delete KitER-0069
2011-2023 6.7L Ford Powerstroke Diesel EGR Delete KitER-0088
