Before Installing Your Pickup Exhaust Tip.Maintain a 1-inch bumper clearance to prevent heat damage. Align the slant-cut with the body line, then secure the clamp with a high-torque wrench. Re-tighten after 50 miles. For maximum security, a tack weld at the joint is highly recommended.
1.Measure and clean pipe to confirm fitment, ensure tailpipe free of debris.
2.Safety Check: Ensure engine off and exhaust system cool.
Position the exhaust pipe properly and tighten the bolts. The tailpipe may shift slightly. After readjusting, ensure the slash-cut tip stays parallel to the vehicle body.
1.Slide the tip onto the tailpipe to the desired depth, ensuring a secure fit.
2.Adjust clearance to keep 1 inch space between tip and bumper to avoid heat damage to plastic.
Step 3:2.Adjust clearance to keep 1 inch space between tip and bumper to avoid heat damage to plastic.
