I've had my 1990 F-150 with the 5.0 for about eight years now, and like most of these old trucks, it came with a tangled mess of vacuum lines and emissions equipment that the previous owners had already started hacking apart. The EGR system was still there, barely, but it wasn't working right. Vacuum leaks, carbon buildup, and that occasional pinging under load told me the system was doing more harm than good.
After reading through forums and talking to other owners, I decided to pull the whole EGR setup off. The problem was what to do with that hole in the intake manifold once the valve was gone. Just leaving it open wasn't an option. A piece of sheet metal with some RTV wasn't going to cut it long-term.
That's when I started looking into proper block-off plates. Not the thin, stamped stuff that warps after a few heat cycles, but something machined that would actually seal and stay sealed. Here's what I learned about cleaning up these old Ford engines and why a quality block-off plate makes a difference.
The EGR Situation on These Trucks
These 1983-1997 Ford trucks came with EGR systems from the factory, and they worked well enough when new. But we're talking about vehicles that are 30-40 years old now. The vacuum lines get brittle and crack. The EGR valves clog with carbon. The passages in the intake manifold get restricted.
Some guys try to keep them working. They replace vacuum lines, clean the valve, chase down leaks. And that's fine if you've got the patience for it. But a lot of owners eventually reach the same conclusion: it's easier to just remove the whole system.
The EGR system on these trucks recirculates exhaust gas back into the intake to lower combustion temperatures. It's supposed to reduce emissions. But on an older engine, a malfunctioning EGR can cause driveability issues, pinging under load, and rough idle. At a certain point, it's just not worth the headache.
What Happens When You Remove the EGR
Once you pull the EGR valve off, you're left with an open port in the intake manifold. On some engines, there's also an opening at the exhaust crossover where the EGR tube connected. You can't just leave these open. You'll have vacuum leaks, exhaust leaks, and all kinds of running issues.
Some guys make their own block-off plates from sheet metal. That works temporarily, but thin metal warps with heat. A couple heat cycles and it's no longer flat, and now you've got a leak again. Others use RTV and call it good, but that's a temporary fix at best.
A proper block-off plate solves all of that. It's machined to be perfectly flat, so it seals against the manifold surface. It's thick enough that it won't warp or deform over time. And once it's installed, you never have to think about it again.
What Makes This Plate Different
The TruckTok plate is machined from 6061 T6 aluminum. That's aircraft-grade material, not the cheap stuff. T6 refers to the tempering process that makes the aluminum stronger and more stable. It won't crack, won't warp, won't deform no matter how many heat cycles it goes through.
CNC machining means every plate is identical. The surface is perfectly flat, so it mates to your intake manifold with no gaps. No filing, no grinding, no trying to make it fit. It bolts right on.
The thickness matters too. Thinner plates can distort when you tighten the bolts, especially if the manifold surface isn't perfectly flat. This one is thick enough that it stays flat under clamping force. You torque it down, and it seals.
Installation Is Straightforward
Putting one of these on is about as simple as it gets. Remove the EGR valve, clean the mounting surface on the intake manifold, and bolt the plate in place. Use the factory bolts if they're in good shape, or pick up new ones at the hardware store. That's it.
The note in the product description about measuring the pitch of the baffle is worth paying attention to. There were variations in these engines over the years, and the bolt spacing changed at certain points. Measure yours before ordering to make sure you get the right one.
The Simulator Connection
The product description mentions using this plate "together with the simulator" to delete the EGR smoothly. That's worth understanding. This plate blocks the physical flow of exhaust gas. But on some of these trucks, the computer still expects to see the EGR system working. If you just pull the valve and put a plate on, you might get a check engine light.
That's where an EGR simulator comes in. It plugs into the wiring harness where the EGR valve sensor connected and tells the computer everything is fine. The plate handles the physical side, the simulator handles the electrical side. Together, they make the delete complete with no warning lights.
Not every truck needs the simulator. Some of these older Fords don't monitor the EGR closely enough to care. But if you've got a later model or one with a more sensitive computer, the simulator is worth considering.
Why Clean Up the Engine Bay
Beyond the functional benefits, there's something satisfying about a clean engine bay. The EGR system adds a lot of clutter. Vacuum lines running everywhere, the valve itself taking up space, the tube running from the exhaust crossover. Removing all of it makes the engine look simpler, more purposeful.
For anyone who works on their own truck, fewer vacuum lines means fewer things to troubleshoot later. No more chasing leaks, no more wondering if the EGR diaphragm is still good. Just a clean, simple setup that runs the way it should.
The Long-Term Benefit
These old Ford trucks are getting harder to find in good condition. The ones that survive are either garage queens or daily drivers that have been kept on the road through sheer determination. For those of us in the second category, any modification that reduces complexity and improves reliability is worth doing.
The EGR system was a good idea in 1985, but on a 30-year-old truck, it's often more trouble than it's worth. Removing it with a quality block-off plate eliminates a potential failure point and simplifies the whole engine.
What You End Up With
After installing the plate, the engine bay looks cleaner. No more EGR valve sticking up where it doesn't belong. No more vacuum lines running everywhere. Just a smooth, flat plate where the valve used to be.
The truck runs the same, maybe better if the old EGR was sticking open and causing issues. No more pinging under load. No more rough idle from vacuum leaks. Just a reliable old Ford doing what it does best.
For anyone with one of these trucks—whether it's an F150, F250, F350, Bronco, Mustang, or any of the other models listed—this is one of those modifications that just makes sense. It's cheap, it's easy, and it solves a problem before it becomes a problem.
If you've removed the EGR from your old Ford, did you run into any issues with the check engine light or vacuum leaks? Drop your experience below.
