I've got a 1990 F-250 with the 5.8L that I've been tinkering with for the past few years. It's one of those trucks that just keeps going—no computers controlling the fuel, no complicated sensors everywhere, just a solid gas engine that'll run forever if you don't mess with it. But like a lot of us who work on these old Fords, I started running into issues with the EGR system.
The previous owner had already deleted the EGR hardware—typical move for someone who wanted a cleaner engine bay and didn't care about emissions. But the check engine light was on, bright and annoying, every time I started the truck. It didn't affect how it ran, but that little orange glow on the dash drove me crazy.
I tried a few things. Resistors, jumpers, even pulling the bulb (don't do that—you'll forget it's gone when a real problem pops up). Nothing worked right. Either the light stayed on, or I lost the ability to see other trouble codes when something else went wrong.
Then I found these little EGR simulator plugs. They're dead simple—just plug into the wiring harness where the EGR valve used to connect, and they tell the computer everything is fine. No more check engine light, but the computer still works for other codes. After running one for about six months, here's what I learned.
The EGR valve on these trucks recirculates exhaust gas back into the intake to lower combustion temperatures. It's a simple vacuum-operated system with a sensor that tells the computer whether the valve is working. When everything functions correctly, you never think about it.
But these trucks are 30-plus years old now. Vacuum lines get brittle and crack. EGR valves clog with carbon. Ports in the intake get restricted. At some point, a lot of owners decide it's easier to just delete the whole system rather than chase vacuum leaks and clean carbon buildup.
The problem is the computer. It expects to see that EGR system working. When it doesn't, it lights up the check engine light and stores a code. Usually code 33 or 332, which both relate to EGR issues.
The computer on these Fords runs a diagnostic routine. It checks the EGR system at specific times—usually during deceleration or steady cruising. When it doesn't see the expected signals, it assumes something's wrong and lights up the dash.
Some guys try to trick it with resistors. Sometimes that works. Sometimes it doesn't. The problem is that the EGR system on these trucks isn't just a simple on-off switch. The sensor provides position feedback, so the computer knows how far the valve is open.
A resistor might fool the computer into thinking the valve is closed, but then the computer never sees the "open" signal it expects during its tests. Result? Check engine light.
Other guys pull the bulb or put tape over it. That's a terrible idea because then you won't know when something else goes wrong. The check engine light exists for a reason—it's your early warning system for all kinds of problems.
How it works: The simulator sends the right signals back to the computer to make it think the EGR system is still there and functioning normally. It reports that the valve is closed when it should be closed and open when it should be open. The computer runs its tests, sees the expected responses, and leaves the check engine light off.
The locking connector: The plug uses the same factory-style locking tab as the original harness. It clicks in securely and won't vibrate loose. No need for electrical tape or zip ties to hold it in place, though the instructions mention using them for extra security.
What it doesn't do: This isn't a device that disables the EGR functions. It doesn't physically block anything or prevent the system from working. It just simulates the sensor signals so the computer stays happy. If your EGR system is still intact, this won't disable it—it'll just fool the computer into thinking everything's fine even if the hardware is gone.
The code situation: The instructions mention that after installing this, you might still get code 33 or 332 when you run a diagnostic test. That's normal. The code will be stored in memory, but it won't trigger the check engine light unless there are other codes present. The light stays off, but the computer still works for other problems.
No more annoying light: The most obvious benefit is that the check engine light stays off. No more staring at that orange glow every time I drive. The dash looks normal again.
Other codes still work: This is the big one. The computer still monitors everything else—oxygen sensors, coolant temp, throttle position, all of it. If something else goes wrong, the light will come on and I'll know about it. You don't lose that safety net.
Clean installation: The plug just clicks into the harness and tucks away. No dangling wires, no electrical tape mess, nothing that looks like a backyard hack job. It looks factory.
Zero maintenance: Once it's plugged in, there's nothing to do. No adjustments, no cleaning, no checking. It just sits there doing its job.
Passing visual inspections: If you're in an area where they don't do sniffer tests but do check for obvious tampering, this keeps the harness looking intact. The EGR valve might be gone, but the electrical connection looks like it's still there.
Step 1: Find the EGR valve sensor connector on your truck. It's usually on or near the EGR valve itself. Disconnect it from the valve.
Step 2: Check that the connector is clean. The instructions mention that dielectric grease inside the connector is normal—leave it alone. It's there to prevent corrosion.
Step 3: Plug the simulator into the wiring harness. Push it until the locking tab clicks. That's it.
Step 4: Secure it if you want. The instructions suggest using a zip tie or electrical tape to keep it from bouncing around. I used a small zip tie to attach it to the nearby wiring harness.
Step 5: Start the truck. The check engine light should be off. If it's on, check your connection.
That's the whole process. No tools required, no special skills, no cutting or soldering.
Off-road use only: This device is explicitly labeled for off-road and race track use only. Removing or disabling emissions equipment on a vehicle driven on public roads is a federal violation. The warnings are there for a reason.
Not a defeat device: The description is careful to note that this is not an EGR defeat device. It doesn't disable anything—it just simulates the sensor signals. The distinction matters legally.
Code 33/332 is normal: If you run a diagnostic test after installing this, you'll probably see code 33 or 332. That's expected. The simulator makes the computer think everything's fine for normal operation, but the code might still be stored in memory. It won't trigger the light unless other codes are present.
Your responsibility: The fine print makes clear that the end user bears full responsibility for how this device is used. If you install it on a street-driven truck, that's on you.
If you've already removed the EGR hardware or you're planning to, you're going to have a check engine light staring at you every time you drive. You could ignore it, but then you lose the ability to know when something else goes wrong.
The TruckTok EGR Simulator solves that problem. It plugs into the factory wiring harness, sends the right signals to the computer, and keeps the check engine light off while still letting the computer monitor everything else. It takes two minutes to install, requires no tools, and doesn't require any permanent modifications to your truck.
What you get:
If you've dealt with EGR-related check engine lights on your old Ford, what did you do to fix it? Drop your experience below.
Part 1: The EGR Situation on These Old Fords
The 1986-1995 Ford trucks with the 2.8L, 4.9L, 5.0L, 5.8L, and 7.5L engines came with EGR systems from the factory. It was part of the emissions package, and it worked well enough for its time.The EGR valve on these trucks recirculates exhaust gas back into the intake to lower combustion temperatures. It's a simple vacuum-operated system with a sensor that tells the computer whether the valve is working. When everything functions correctly, you never think about it.
Part 2: Why Just Removing the Hardware Doesn't Work
If you've pulled the EGR valve off your truck, you've probably dealt with the check engine light aftermath.The computer on these Fords runs a diagnostic routine. It checks the EGR system at specific times—usually during deceleration or steady cruising. When it doesn't see the expected signals, it assumes something's wrong and lights up the dash.
Part 3: What This Little Plug Actually Does
The TruckTok EGR simulator is a small device that plugs directly into the wiring harness where your EGR valve sensor used to connect. That's it. No splicing, no cutting, no resistors to solder.How it works: The simulator sends the right signals back to the computer to make it think the EGR system is still there and functioning normally. It reports that the valve is closed when it should be closed and open when it should be open. The computer runs its tests, sees the expected responses, and leaves the check engine light off.
Part 4: What You Gain by Using One
After installing one of these on my F-250, several things changed.No more annoying light: The most obvious benefit is that the check engine light stays off. No more staring at that orange glow every time I drive. The dash looks normal again.
Part 5: The Installation Reality
Installing this thing takes about two minutes. I'm not exaggerating.Step 1: Find the EGR valve sensor connector on your truck. It's usually on or near the EGR valve itself. Disconnect it from the valve.
Part 6: The Important Caveats
The product description includes some language that's worth paying attention to.Off-road use only: This device is explicitly labeled for off-road and race track use only. Removing or disabling emissions equipment on a vehicle driven on public roads is a federal violation. The warnings are there for a reason.
Part 7: The Verdict
The 1986-1995 Ford trucks with the 2.8L, 4.9L, 5.0L, 5.8L, and 7.5L engines are old enough now that a lot of owners are dealing with tired EGR systems. Vacuum leaks, clogged valves, cracked lines—it's all part of owning a 30-year-old vehicle.If you've already removed the EGR hardware or you're planning to, you're going to have a check engine light staring at you every time you drive. You could ignore it, but then you lose the ability to know when something else goes wrong.
What you get:
- No more annoying check engine light
- Other trouble codes still work
- Factory-style connector that clicks in securely
- Zero maintenance once installed
- A clean, professional-looking solution
