Universal Stainless Steel Exhaust Tip, Size 4" to 5
Before Installing Your Pickup Exhaust Tip.Maintain a 1-inch bumper clearance to prevent heat damage. Align the slant-cut with the body line, then secure the clamp with a high-torque wrench. Re-tighten after 50 miles. For maximum security, a tack weld at the joint is highly recommended.
1.Measure and clean pipe to confirm fitment, ensure tailpipe free of debris.
2.Safety Check: Ensure engine off and exhaust system cool.
1.Slide the tip onto the tailpipe to the desired depth, ensuring a secure fit.
2.Adjust clearance to keep 1 inch space between tip and bumper to avoid heat damage to plastic.
Position the exhaust pipe properly and tighten the bolts. The tailpipe may shift slightly. After readjusting, ensure the slash-cut tip stays parallel to the vehicle body.
