WHAT are the warning signs that my 68RFE is starting to slip under load?
FullSendFrank
I’m towing a 12k lb trailer with my 2021 RAM 2500 and the 1-2 shift feels a bit 'mushy' lately. WHAT exactly does a slipping 68RFE feel like? HOW much heat is too much for these trans? I’m seeing 210°F on long grades—should I be worried?
I’ve been towing with the 68RFE for years. What people don't realize is that these transmissions depend heavily on line pressure to keep the clutches from burning. How I keep mine alive: I NEVER tow in 6th gear on grades. I always lock out 6th, and sometimes 5th, to keep the trans from "hunting" for gears.
That mushy feeling is the computer trying to smooth out the shift to be "comfortable," but comfort kills these gearboxes under load. Get a custom trans tune (like RevMax or similar) that increases the line pressure. It will make the shifts feel much firmer, which sounds worse but is actually much better for the life of the clutches.
20k miles is early for it to be failing, but 12k lbs is a lot of weight for a stock 68RFE on long grades. The "mushy" 1-2 shift is a classic sign of low line pressure. Honestly, at those temps, you’re thinning out the fluid. Do a fluid and filter change now to see if there’s any metal in the pan. Better safe than sorry.
Regarding your temperatures, 210°F on a long grade while pulling 12k lbs is getting into the "danger zone" for a stock 68RFE. While modern synthetic fluids can handle it briefly, these transmissions generally prefer to stay under 190°F. If you consistently see 210°F+, your fluid is breaking down and losing its lubricating properties, which accelerates clutch wear. HOW much heat is too much? If you hit 230°F, pull over immediately. I’d highly recommend an aftermarket thermal bypass valve (TBV) delete; it’s a cheap mod that helps the trans cooler actually do its job sooner.
Regarding your temps, 210°F is the limit where you should start being concerned. While modern synthetic fluid can handle 210°F for short bursts, a healthy 68RFE ideally wants to stay between 170°F and 190°F. HOW much heat is too much? If you hit 230°F, you are actively cooking the seals and glazing the clutches. The fact that you're hitting 210°F suggests your fluid is already thinning out, which reduces the clamping pressure on the clutches, leading to the "mushy" feeling you're experiencing. I’d highly recommend a fluid flush and an aftermarket thermal bypass delete to help keep those temps under 200°F.
