What causes the VGT actuator to fail and HOW do I know if it’s just soot buildup?
JustOneMorePart
My 2014 6.7L just threw the dreaded P00AF code and my exhaust brake has completely stopped working. The truck feels like a dog off the line. I’ve heard the actuators on these Holset turbos are notorious for dying.
Is there a way to clean the soot out of the sliding nozzle to save it, or am I looking at a $1,000 replacement part? I’m considering upgrading to a City Diesel or Fleece actuator instead of another OEM one—what’s the consensus on those?
Don't be surprised if the soot is what killed the actuator in the first place. These VGTs need to be "exercised." If you’re a light-footed driver or spend a lot of time idling, the soot builds up on the sliding nozzle and the actuator has to work ten times harder to move it until it eventually burns out. Once you get the new one on, make sure you run with your exhaust brake ON all the time. It forces the nozzle to move more frequently and helps keep that track clean. It’s an expensive lesson, but the exhaust brake is your best friend for turbo longevity.
That P00AF is a classic. You can try a cleaning kit, but usually, it’s a temporary fix if the internal gears are already stripped. What most of us do is switch to the City Diesel or Fleece actuator—they are much more durable than OEM and don't require the annoying dealer calibration software.
How many miles are on that turbo? If the internal sliding nozzle is physically seized from soot, a new actuator won't solve it. I’d highly recommend pulling the actuator first to see if the sector gear moves freely by hand. If it’s stuck, you might need a full turbo cleaning or a replacement. What does the movement feel like?
