1" x 30ft Heavy Duty Kinetic Recovery Rope Kit 35,000 lbs Break Strength with 2pcs Soft Shackles for Trucks
This is the installation process for the TH-0016: 1" x 30ft Heavy Duty Kinetic Recovery Rope Kit 35,000 lbs Break Strength with 2pcs Soft Shackles for Trucks, for your reference during the installation process.
Connect the Soft Shackle to the Recovery Rope.
Take one end of the Kinetic Recovery Rope. Slide the eye of the Soft Shackle through the loop at the end of the recovery rope.
Secure the Shackle: Open the loop of the soft shackle, slide it over the large knot, and pull it tight to lock it in place.
Repeat Steps 1 and 2 to attach the other end of the rope to the pulling vehicle. Ensure the rope is not twisted or tangled.
