This is the installation process for the DP-0270: 2013-2018 6.7L Dodge Ram Cummins 4" Downpipe back DPF Delete Pipe,provided for your reference during installation.
Remove all sensors and DEF injector connections from the downspout, SCR, and diesel particulate filter.
2.Loosely tighten the flange to the flange end of the downspout and insert the metal, install
the #1 pipe, and insert the hanger into the OEM rubber insulator.
If necessary, add an extension pipe at the end of pipeline # 4. For MegaCab / SB models, an extension tube of #3 -is required; For the CrewCab / LB model, an extension tube of #4 is required.
Next, install the # 2 muffler delete pipe. The # 5 pipe is located on the axle pipe and the # 6 tail pipe. Place the hanger into the OEM rubber hanger together.(* Note: For some trucks, you need to move two factory rubber insulators from the factory exhaust to the metal hangers on the truck cross beam in front of the rear axle.)
The pipeline installation should be moderately tight, and the new exhaust system should be adjusted to meet the clearance and appearance requirements.Tighten all connections and fixtures evenly, starting from the front flange connection and then proceeding with the subsequent connections.
Use a flat head screwdriver to pry out the clamps from three positions on the flange. Remove the water pipe and keep the clip as it will be reused.Step 3:
1.Before installing pipelines and mufflers, ensure that fixtures are placed at all pipeline connections.2.Loosely tighten the flange to the flange end of the downspout and insert the metal, install
2013-2018 6.7L Ram Cummins 5" Turbo Back DPF Delete Pipe (With Muffler )
2013-2018 6.7L Ram Cummins Diesel EGR Cooler Throttle Valve Delete Kit
2013-2018 6.7L Ram 2500 3500 Turbo Diesel 4" Exhaust Tube Pipe Kit
2009-2019 6.7L Dodge Ram Cummins Coolant Bypass Barb Leak repair Adapter Kit
2007-2018 6.7L Dodge RAM 2500 3500 Cummins Diesel 3.5inch High Flow Intake Manifold Elbow Tube Horn
2007.5-2018 6.7L Dodge Cummins 2500 3500 CCV Black Crankcase Ventilation Diesel
