2017-2023 6.6L GM Chevy Duramax L5P Tuner Harness Plug Kit
This is the installation process for the ER-0330: 2017-2023 6.6L GM Chevy Duramax L5P Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2017-2023 6.6L GM Chevy Duramax L5P diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
ID
Name
Location
Installation
1 - 6
EGT / NOx Sensor Plugs
Located along the exhaust system from the downpipe to the SCR/DPF sections.
Connect to the engine/chassis harness leads where the Exhaust Gas Temp and NOx sensors were unplugged.
7 & 10
DEF Pump & Injector Plugs
Located at the DEF tank assembly and the exhaust decomposition pipe.
Plug into the harness connectors that previously powered the DEF pump and the dosing injector.
8
EGR Valve Plug
Located on the top of the engine near the intake manifold and EGR cooler.
Secure this to the large factory harness connector that was removed from the EGR valve motor.
9
Main Intake / Throttle Plug
Near the air intake horn or throttle body.
Seals the high-pin count connector for the electronic throttle valve.
11
Exhaust Pressure Sensor Plug
Mounted on the frame or engine near the pressure lines.
Inserts into the harness connector for the exhaust backpressure sensor.
12
Auxiliary Sensor Plug
Variable location depending on specific L5P year model.
Seals any remaining open auxiliary emissions sensor on the chassis harness.
