This is the installation process for the ER-0324: 2023-2025 6.7L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2023–2025 Ford 6.7L Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
1 - 3 | Main Harness (Large) | Engine / DEF Tank | Connect to the largest main connectors on the EGR valve and the DEF pump assembly. |
4 | EGR Temp Sensor | Passenger side engine bay | Specifically designed for the brown/tan EGR temperature sensor harness connector. |
5 | Throttle Body | Intake manifold inlet | Connects to the large multi-pin intake throttle valve actuator harness. |
6 - 8 | EGT Sensors 1-3 | Front/Mid exhaust pipe | Plug into the first three factory exhaust gas temperature (EGT) sensor connectors. |
9 | EGT Sensor 4 | Rear exhaust pipe | Connect to the 4th EGT sensor; features a unique keyway different from IDs 6-8. |
10 | DPF Pressure Sensor | Frame rail | Secure to the round-style exhaust backpressure / differential pressure sensor plug. |
11 | Emission Module | Rear chassis area | Plugs into the large flat-style main emissions control module connector. |
12 | NOx Sensor (Medium) | Mid-chassis | Connect to the NOx sensor harness. |
13 - 15 | Small Accessory | DEF Tank / EGR Bypass | Secure to the DEF heater, fluid level sensor, or the EGR bypass solenoid. |
16 | Auxiliary/Coolant | Engine bay | Green specialized plug for secondary cooling or auxiliary temperature sensors. |
