2020-2022 6.7L Ford Powerstroke Tuner Harness Plug Kit
This is the installation process for the ER-0323: 2020-2022 6.7L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2020–2022 Ford 6.7L Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
ID
Name
Location
Installation
1
EGR Main Harness
Engine bay, passenger side
Connects to the large main harness previously feeding the EGR cooler assembly.
2
DEF Pump Main
Above the DEF tank
Seals the high-current main power and data feed for the DEF pump.
3
NOx Sensor 1
Exhaust downpipe (front)
Caps the harness for the first Nitrogen Oxide sensor located near the turbo.
4
Fuel Pressure/Temp
Engine fuel rail area
Small brown plug used for auxiliary fuel system sensor shielding.
5
EGR Actuator
EGR assembly
Small green plug specifically for the EGR butterfly valve/actuator connector.
6, 11-15
EGT Sensors (Set of 6)
Throughout the exhaust system
Caps all Exhaust Gas Temperature sensors (EGT A, B, C, D, E, and Downpipe sensor).
7
DEF Level & Quality
Top of the DEF tank
Caps the multi-pin connector for the DEF fluid tank level and quality sensor.
8
NOx Sensor 2
Mid-exhaust section
Caps the harness for the second (rear) Nitrogen Oxide sensor.
9
DEF Injector (Doser)
Exhaust downpipe
Caps the electrical connector for the DEF urea dosing injector.
10
Throttle Valve
Intake manifold
Seals the connector for the electronic intake throttle valve.
