2016-2018 6.7L Ram Cummins Tuner Harness Plug Kit
This is the installation process for the ER-0327: 2016-2018 6.7L Ram Cummins Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2016-2018 6.7L Ram Cummins diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
ID
Name
Location
Installation
1 - 5
EGT/NOx Sensor Plugs
Along the exhaust frame rail
Connect to the 5 small factory harness leads where the Temperature (EGT) and NOx sensors were disconnected.
6
DEF Pump Main Plug
Above the rear axle / DEF tank
The largest square plug; connects to the primary main power harness for the DEF pump assembly.
7
Large DEF Tank Connector
Side of the DEF tank
Wide flat-style cap; fits the larger secondary sensor connector on the DEF tank.
8
Pressure Sensor (Large)
Mid-chassis / Passenger side
Longer flat-faced plug; protects the primary SCR/DPF pressure sensor harness.
9
Pressure Sensor (Small)
Mid-chassis/Underbody
Compact rounded-rectangular plug; fits the secondary or auxiliary pressure sensor leads.
10
DEF Injector Plug
Exhaust pipe mid-section
Medium-width flat cap; specifically sized for the DEF injector (doser) harness connector.
11
Vent Tube Plug
DEF Tank area
Small white plastic barb; insert into the open DEF vent line to block dust and debris.
12
Throttle/Sub-Harness Plug
Engine bay or chassis rail
Multi-pin plug with red locking tab; protects the 2016+ specific throttle or auxiliary sub-harness.
13
8-Pin Main Distribution Cap
Main chassis harness junction
Large 8-hole cap; secures the high-pin count junction connector on the frame.
14
Gray Auxiliary Sensor Plug
Underbody emissions harness
Gray 4-hole oval plug; used for specific trim levels or variations in the NOx control module.
15
EGR Actuator Plug
Top of the engine (EGR area)
Round-base connector; protects the EGR motor/actuator harness after the EGR system is bypassed.
