This is the installation process for the ER-0326: 2013-2015 6.7L Ram Cummins Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2013-2015 6.7L Ram Cummins diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
1-5 | EGT / NOx Sensors | Along the exhaust piping | Plug these into the factory harness side after removing the 4-5 sensors from the exhaust pipe. |
6 | DEF Pump Main | Above the DEF tank | The largest square plug. Used to seal the main power supply harness leading to the DEF pump. |
7 | EGR Temp Sensor | Under hood, at EGR cooler | The smallest rounded plug. Seals the connector for the EGR temperature monitor. |
8 | EGR Actuator | Top of engine at EGR valve | A longer plug with a specific back-slot. Seals the harness for the main EGR valve solenoid. |
9 | Small Chassis Plug | Along frame rail / rear axle | Slightly smaller/narrower than ID 10. Seals smaller auxiliary or communication connectors on the chassis. |
10 | Large Chassis Plug | Along frame rail / rear axle | Slightly wider than ID 9. Seals the medium-sized communication or signal connectors on the chassis. |
11 | Throttle Body | Intake manifold / Throttle valve | Features a red slide lock. Insert into the throttle valve harness and push the red tab to the locked position. |
12 | DEF Level Sensor | Top or side of the DEF tank | Grey housing. Specifically keyed to match the DEF tank fluid level and pressure sensor harness. |
13 | DEF Line Heater | Near DEF pump / line junctions | Black heavy-duty plug. Protects the high-current power supply for the DEF line heating system. |
14 | Main Frame Plug | Driver-side rear frame rail | Large grey multi-pin connector. Seals the primary communication hub for the aftertreatment system. |
15 | Vent Cap | Various vacuum/vent lines | White silicone cap used to plug small disconnected vacuum lines or open vent ports. |
