This is the installation process for the ER-0322: 2017-2019 6.7L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2017–2019 Ford 6.7L Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
1 - 5 | EGT / NOX Sensors | Located along the entire exhaust pipe (from downpipe to tailpipe). | Use these 5 identical plugs to seal all exhaust gas temperature and NOX sensor harness connectors. |
6, 7 | DEF Tank System | Located at the top of the DEF (Diesel Exhaust Fluid) tank. | Seals the urea heater and level sensor harness connectors after disconnecting from the tank. |
8 | EGT / Auxiliary | Mid-chassis or along the exhaust stream. | Seals extra temperature monitoring points or auxiliary sensors. |
9 | Auxiliary Sensor | Various locations depending on vehicle trim/options. | Seals any remaining small-format chassis sensor connectors. |
10 | DEF Injector | Located at the urea injector on the exhaust pipe. | Disconnect the injector power line and insert this plug to prevent corrosion. |
11 | EGR Main Connector | Under the hood, near the firewall on the EGR assembly. | Disconnect the primary EGR valve harness and insert this large black plug. |
12, 13 | Large Controller Plugs | 12: SCR Control Module (Frame rail) 13: DPF Pressure Sensor (Near transmission) | Use these large rectangular plugs to seal the main emission control module connectors. |
14, 15 | Engine Actuators | 14: Intake Throttle Valve 15: EGR Actuator | Brown round plugs. Seal the two main engine-top power actuators after tuning. |
