This is the installation process for the ER-0320: 2011-2014 6.7L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2011–2014 Ford 6.7L Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.Elimination of Hazards : Prevents electrical interference caused by exposed connectors, ensuring the stable and reliable operation of the modified system.
1 | Vacuum Line Plug | Engine Bay / Near EGR | Insert into any disconnected small vacuum or pressure hoses to prevent leaks. |
2 | DEF Level/Temp | Top of DEF Tank | Seals the sensor connector at the top of the original urea tank. |
3-4 | EGT Sensors | Exhaust Pipe | Seals the factory EGT sensor connectors along the mid-exhaust section. |
5-6 | EGT Sensors | Downpipe / Tailpipe | Seals the remaining temperature sensors in the exhaust system. |
7 | DEF Pump Main | Chassis Frame Rail | CRITICAL: Seals the large main power harness for the DEF pump assembly. |
8 | EGR Valve Main | Engine Bay - Top | CRITICAL: Seals the main engine harness after the EGR valve is removed. |
10 | DEF Injector | Mid-Exhaust Section | Seals the wiring harness at the location of the original urea nozzle. |
11 | EGR Throttle / Servo | Engine Bay - Intake | Seals the 3-wire connector for the intake throttle or EGR regulator. |
12 | Pressure Sensor | Exhaust System | Seals the exhaust back-pressure sensor connector located near the DPF. |
13-17 | Small Spares | Along the Frame Rail | 2-wire plugs used for various pressure or redundant temp monitoring points. |
18-19 | NOx Sensor Plugs | Exhaust / Frame Rail | VITAL: High-security plugs for Front/Rear NOx modules. Push yellow tab to lock. |
20 | Secondary Heater | DEF Tank Area | Seals the urea heater or secondary pressure sensor (model specific). |
