2011-2014 6.7L Ford Powerstroke Tuner Harness Plug Kit
This product is intended exclusively for off-road competition or off-road use. Prior to installation, you must ensure that the vehicle has been flashed with a compatible tuning program (Tune). During installation, it is imperative to use zip ties to secure the wiring harness in a heat-shielded location, positioned well away from the exhaust system. The user assumes full responsibility for any vehicle damage or legal liabilities resulting from illegal use, failure to apply the necessary tuning program, or improper installation (such as the melting of the wiring harness).
This is the installation process for the ER-0320: 2011-2014 6.7L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2011–2014 Ford 6.7L Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
Elimination of Hazards : Prevents electrical interference caused by exposed connectors, ensuring the stable and reliable operation of the modified system.
Waterproof Sealing : Prevents rain, wash water, or road spray from entering open connectors and causing short circuits.
Corrosion and Dust Protection : Blocks dirt, debris, and road salt from corroding the connector pins, thereby safeguarding sensitive signal circuits.
ID
Name
Location
Installation
1
Vacuum Line Plug
Engine Bay / Near EGR
Insert into any disconnected small vacuum or pressure hoses to prevent leaks.
2
DEF Level/Temp
Top of DEF Tank
Seals the sensor connector at the top of the original urea tank.
3-4
EGT Sensors
Exhaust Pipe
Seals the factory EGT sensor connectors along the mid-exhaust section.
5-6
EGT Sensors
Downpipe / Tailpipe
Seals the remaining temperature sensors in the exhaust system.
7
DEF Pump Main
Chassis Frame Rail
CRITICAL: Seals the large main power harness for the DEF pump assembly.
8
EGR Valve Main
Engine Bay - Top
CRITICAL: Seals the main engine harness after the EGR valve is removed.
10
DEF Injector
Mid-Exhaust Section
Seals the wiring harness at the location of the original urea nozzle.
11
EGR Throttle / Servo
Engine Bay - Intake
Seals the 3-wire connector for the intake throttle or EGR regulator.
12
Pressure Sensor
Exhaust System
Seals the exhaust back-pressure sensor connector located near the DPF.
13-17
Small Spares
Along the Frame Rail
2-wire plugs used for various pressure or redundant temp monitoring points.
18-19
NOx Sensor Plugs
Exhaust / Frame Rail
VITAL: High-security plugs for Front/Rear NOx modules. Push yellow tab to lock.
20
Secondary Heater
DEF Tank Area
Seals the urea heater or secondary pressure sensor (model specific).
