This is the installation process for the ER-0321: 2015-2016 6.7L Ford Powerstroke Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2015-2016 Ford 6.7L Powerstroke diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
1 | DEF Pump Main | DEF Tank (Side) | Clean urea crystals before inserting. |
2 | DEF Auxiliary | DEF Tank (Side) | Physical fitment prevents mismatch. |
3 | DEF Level/Heater | Top of DEF Tank | Seal immediately to prevent debris. |
4-5 | EGR Aux Connectors | Engine Bay (Top) | Check clip orientation for 15-16 models. |
6 | NOx / Rear Sensor | Tailpipe Section | Do not mix with 7-10. |
7-10 | EGT Sensors | Exhaust Pipe | Ensure a "click" sound to lock. |
11 | Main Harness (Grey) | Mid-Frame Rail | Match by Color: Grey to Grey. |
12 | Main Harness (Black) | Mid-Frame Rail | Match by Color: Black to Black. |
13-14 | Exhaust Pressure | Mid-Exhaust / Firewall | Keep harness facing down to avoid water. |
15 | Accessory Plug | Engine Bay Side | Use only if a matching OEM plug exists. |
16 | EGR Main ControlEGR | EGR Assembly (Top) | Yellow lock is a secondary safety. |
