2011-2016 6.6L GM Chevy Duramax LML Tuner Harness Plug Kit
This is the installation process for the ER-0329: 2011-2016 6.6L GM Chevy Duramax LML Tuner Harness Plug Kit,provided for your reference during installation.
This kit is specifically designed for 2011-2016 6.6L GM Chevy Duramax LML diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
ID
Name
Location
Installation
1
EGR Main Connector
Top of the engine, near the EGR cooler assembly.
Connects to the large main harness that previously controlled EGR functions.
2
EGR Actuator Plug
Engine bay, on the EGR valve/cooler bypass.
Seals the secondary actuator control harness for the EGR system.
3
Front NOx Sensor
Exhaust downpipe, near the back of the turbo.
Seals the harness connector for the upstream (front) NOx sensor.
4
DEF Injector (Doser)
Exhaust pipe, usually located before the SCR catalyst.
Plugs into the harness that previously powered the urea dosing valve.
5
Rear NOx Sensor
Exhaust pipe, located in the tailpipe section.
Seals the harness connector for the downstream (rear) NOx sensor.
6
EGT Main Interface
Junction of the main exhaust sensor wiring loom.
Protects the wide-format interface connector for grouped EGT sensors.
7, 8, 9
EGT / Temp Sensors
Distributed at multiple points along the exhaust piping.
Plugs into individual small-form temperature sensor harness connectors.
10, 11
Auxiliary Sensor Plugs
Located in the engine bay or near the sensor rails.
Seals auxiliary temperature or bypass connectors related to the tuner setup.
12, 13
DPF Pressure Sensors
Under the vehicle, near the original DPF filter area.
Used to seal the harness connectors for the pressure differential sensors.
14
Vent Line Cap
Open vacuum or vent lines (EGR or Tank vents).
Insert into the open end of rubber hoses to prevent dust and debris entry.
