2009.5-2012 6.7L Ram Cummins Tuner Harness Plugs
This is the installation process for the ER-0325: 2009.5-2012 6.7L Ram Cummins Tuner Harness Plugs,provided for your reference during installation.
This kit is specifically designed for 2009.5-2012 6.7L Ram Cummins diesel vehicles. Following the tuning and physical removal of the EGR and DPF systems, numerous unused factory wiring connectors remain within the vehicle's chassis and engine bay.
ID
Name
Location
Installation
1
EGR Actuator (White)
Top of the engine, part of the EGR assembly.
White body plug; seals the EGR motor/actuator connector.
2 & 3
Pressure Sensors (Smallest)
Exhaust system or EGR pressure lines.
Smallest black plugs; used for pressure or secondary sensors.
4
EGR Solenoid A (Small)
Top rear of the engine block.
Rectangle plug, slightly smaller than ID 5.
5
EGR Solenoid B (Large)
Rectangle plug, slightly larger than ID 4.
6
DEF Pump Main (Grey)
Rear frame rail near the DEF tank.
Large grey connector for the main chassis DEF harness.
7, 8, 9, 10, 11
EGT Sensors (Medium)
Along the exhaust pipe (DPF/CAT sections).
Medium-sized black plugs for the EGT sensor leads.
12
Throttle Valve (Large Black)
Intake horn on the driver's side.
Largest black plug with red locking tab; seals throttle valve harness.
