3/4" D-Ring Shackle 52,000 lbs Break Strength Recovery Pulley
This is the installation process for the TH-0027: 3/4" D-Ring Shackle 52,000 lbs Break Strength Recovery Pulley, for your reference during the installation process.
Place a rubber washer on the inside of the bumper hook mount.
Snap the tow hook body into place; the inner force-bearing surface of the tow hook will press against this washer.
Place another rubber washer on the outside of the hook mount (the side where you will install the anti-theft nut).
Finally, place your anti-theft nut and tighten it.
