This is the installation process for the TH-0016: 3/8" S-Hook 31,000 lbs Break Strength Heavy Duty Tow Hook, for your reference during the installation process.
This is a 33,000 lbs high-strength two-way quick-connect hook designed specifically for heavy-duty off-road rescue. It can quickly and safely connect the anchor point and the rope without tools in scenarios such as vehicle extrication, winch self-rescue, and trailer belt extension.
Press the silver safety latch with your finger and thread one end of the S-hook onto the vehicle's attachment point. The attachment point is usually located on the original trailer hitch on the chassis, the D-ring on the trailer hitch, or the winch's rope guide. Check to ensure the latch fully springs back into place.
Thread the tow rope eyelet or winch cable loop onto the other end of the S-hook. Again, ensure the latch returns to its original position.
