WHAT is the real-world benefit of swapping the LLY turbo mouthpiece?
BuiltNotBought
I’m tired of watching my temp gauge climb every time I pull my horse trailer up a decent grade. My 2005 LLY is stock, and I keep hearing that the factory turbo inlet is the biggest bottleneck in the whole system.
Does swapping it for an LBZ or aftermarket mouthpiece actually make a difference in coolant temps, or is it just a way to get more turbo whistle? I’m trying to decide if this is a "must-do" mod before my next big trip this summer.
The real-world benefit is efficiency. Think of the stock LLY inlet as trying to breathe through a straw while running a marathon. By opening that up with an LBZ or S&B mouthpiece, you're reducing the air intake restriction significantly. This leads to lower EGTs and, more importantly, it stops the turbo from acting like a heater for your engine block. While it does add a nice bit of turbo spool sound, the real reason it’s a "must-do" is to keep your head gaskets alive in the long run. If you're towing a horse trailer this summer, don't leave home without swapping it.
The real benefit is lower Exhaust Gas Temperatures (EGTs). When the engine isn't struggling to pull air through that "straw" of a factory inlet, everything runs more efficiently. Does it cure the overheating entirely? Maybe not if your radiator stack is clogged with debris, but it addresses the root cause of the turbo-generated heat. If you go with the LBZ mouthpiece, just remember you'll need to trim your factory intake duct or get a silicone coupler to make it fit. It's a "must-do" if you value your head gaskets.
