I’ve got this high-pitched whistle that only happens when the turbo is at 20+ PSI. It’s not the normal "turbo whine." Is it the boots? Clamps? I’ve checked the obvious ones, any "secret" spots these LMMs leak boost?
Check the intake horn-to-turbo connection. That o-ring gets old and leaks at high pressure. Also, look at the EGR up-pipe—sometimes they crack at the flex joint.
