2" Receiver Heavy Duty Tri-Ball Trailer Hitch Mount with Swivel Shackle Tow Hook 1-7/8"/2"/2-5/16" Balls w/Lock Pin
This high-performance component is designed for towing.Always double-check that all locking pins are fully engaged and locked before towing. Failure to do so may result in property damage or serious injury.
This is the installation process for the TH-0003: 2" Receiver Heavy Duty Tri-Ball Trailer Hitch Mount with Swivel Shackle Tow Hook 1-7/8"/2"/2-5/16" Balls w/Lock Pin, for your reference during the installation process.
Assemble the D-Ring Shackle (Pre-Installation) Before inserting the hitch into the vehicle, align the 3/4" D-ring shackle with the top swivel mount. Insert the shackle pin through the washers and the mount.
Insert the Hitch Mount into Receiver Now, slide the shank of the fully assembled tri-ball hitch into your vehicle’s 2-inch receiver
Secure with Silver Pin & R-Clip Insert the Silver Hitch Pin through the aligned holes. On the other side, push the R-Clip (Safety Pin) through the hole at the end of the silver pin until it is fully seated to prevent the pin from sliding out.
Final Selection & Safety Check Rotate the assembly to choose the correct ball size (1-7/8", 2", or 2-5/16") for your trailer. Double-check that the R-Clip is secure and the shackle rotates freely.
Related installation manual
1" x 30ft Heavy Duty Kinetic Recovery Rope Kit 35,000 lbs Break Strength with 2pcs Soft Shackles for Trucks
2-Inch Receiver Heavy Duty Shackle Recovery Set: Includes 3/4" D-Ring and 5/8" Lock Pin (Covers 38,500 & 70,000 lbs Break Strength Models)
2" Receiver Heavy Duty Adjustable Drop Trailer Hitch Mount with Double Anti-Theft Locking Pin 6" Drop/Rise 12,000 lbs GTW
2" Receiver Heavy Duty Towing Ball Trailer Hitch Mount with Key Lock Pin 3/4" Separate Shackle 50,600 lbs Break Strength
2" Receiver Heavy Duty Shackle Trailer Hitch with 5/8" Hitch Pin 3/4" D Ring Shackle 38,500 Lbs Break Strength
