2007-2018 6.7L Dodge RAM 2500 3500 Cummins Diesel 3.5inch High Flow Intake Manifold Elbow Tube Horn
This is the installation process for the ER-0020: 2007-2018 6.7L Dodge RAM 2500 3500 Cummins Diesel 3.5inch High Flow Intake Manifold Elbow Tube Horn,provided for your reference during installation.
ER-0020
Step1:
1.Remove the heat shield if you have one.
2.Unplug the factory intake air sensor.​
1.Remove any cable bolt to gain more access.
2.Use a wrench to loosen the bolts on the dust cover bracket.If the dust cover gets stuck, use a screwdriver if necessary to loosen the dust cover.
Use a wrench to unscrew the screws of the map sensor on the factory manifold.
Install the map sensor on the Factory manifold onto the new intake horn.
1.Be careful to clean the dirt on the gasket surface near the engine to prevent it from entering the engine.
2.Install the new gasket in the kit.​
1.Install the intake horn, insert one end of the horn into the rubber boot, and secure it with a clamp.
2.Install the intake pipe horn using the original 6 bolts from the factory.
Remove the three screws fixed here, install the dipstick bracket in the kit, and secure it with factory screws.
Related installation manual
2009-2019 6.7L Dodge Ram Cummins Coolant Bypass Barb Leak repair Adapter Kit
2007-2009 6.7L Dodge Ram Cummins Diesel EGR Delete Kit
2010-2012 6.7 Dodge Ram Cummins 4" Turbo-Back DPF Delete Pipe
2007.5-2012 6.7L Dodge Ram Cummins 2500/3500 4" DPF Delete Race Pipe
2007.5-2018 6.7L Dodge Cummins 2500 3500 CCV Black Crankcase Ventilation Diesel
2007.5-2012 6.7L Dodge Ram Cold Air Intake w/Filter
2013-2018 6.7L Ram Cummins Diesel EGR Cooler Throttle Valve Delete Kit
2013-2018 6.7L Ram Cummins 5" Turbo Back DPF Delete Pipe (With Muffler )
2013-2018 6.7L Dodge Ram Cummins 4" Downpipe back DPF Delete Pipe
2013-2018 6.7L Ram 2500 3500 Turbo Diesel 4" Exhaust Tube Pipe Kit
