2020-2023 Chevy Duramax L5P Diesel Can Bus Plugs Connector
This is the installation process for the ER-0214: 2020-2023 Chevy Duramax L5P Diesel Can Bus Plugs Connector, for your reference during the installation process.
ER-0214
Find the plug on the passenger side lower frame rail at the front of the truck and unplug it, then clip one of the black plugs provided in the kit onto the factory socket port.
Note:Before installation, some electrical grease can be applied to prevent corrosion.
Find the second nitrogen oxygen sensor plug under the charging tube on the driver's side of the engine hood and disconnect it. Secure the black plug of the kit to the factory plug port, and also pop out the red label before removing the plug.
1.At the front of the truck, follow the driver's side frame guide rail, find the third plug and unplug it, then clip the largest black plug provided in the kit onto the factory socket port.
2.The gray part of the T-shaped end of the largest black plug provided in the kit needs to be popped inward and fitted into the card slot.
Finally, connect the plug to the card slot of the factory plug and pop back the red label.
2017-2023 6.6L Chevy L5P Duramax Diesel 3.5" Downpipe Exhaust
2017-2024 6.6L Chevy Duramax L5P CCV Reroute/delete kit
2017-2023 6.6L Chevy GMC Duramax L5P diesel EGR Valve Cooler Delete kit
2017-2023 6.6L GM DURAMAX L5P 4"/5" Downpipe Back DPF Delete Pipe
2017-2023 6.6L Chevy GMC Duramax L5P 4" DPF & CAT Delete Race Pipe
