The CP4 Disaster: Disaster Prevention Kit or full DPK?
DieselNerd
My 2015 6.7L is still running the original CP4. I'm terrified of it "grenading" and sending metal shards through my entire fuel system. Is the "Disaster Prevention Kit" enough to save my injectors, or should I just budget for a CP3 conversion?
I totally get the anxiety. I installed a DPK on my '16 last year. Here’s the deal: the DPK doesn't stop the CP4 from failing, but it reroutes the fuel flow so that when the pump inevitably 'grenades,' the metal debris is sent back to the tank and through the return filters instead of being forced into your injectors and fuel rails. A $400 kit can save you from a $10,000 repair bill. If you aren't planning on pushing huge horsepower and just want to protect your investment, the DPK is the most cost-effective insurance you can buy.
I’ve seen too many guys say 'I'll just wait and see' only to end up with a $12,000 repair bill. The DPK (Disaster Prevention Kit) is a no-brainer. It doesn't fix the pump's design flaw, but it acts as a firewall. If the pump fails, you’re looking at a $1,000 pump replacement instead of a total fuel system overhaul including all 8 injectors, rails, and lines. For a few hundred bucks and an afternoon in the garage, why would you even risk it?
While we discuss DPK vs. CP3, don't overlook your fuel filters. The CP4 hates air and it hates water even more. I run a DPK, but I also change my fuel filters every 10k miles religiously and always drain the water separator. If you see even a speck of metal in your primary filter housing during a change, stop driving immediately. That’s your early warning sign that the CP4 is starting to eat itself.
If you're terrified of the "grenade" scenario, the CP3 conversion is the only way to truly sleep at night. A DPK is just a fancy way to fail gracefully. What the CP3 conversion does is replace a fragile, high-pressure-at-low-lubricity pump with a legendary three-piston design that’s been proven for decades.
How to justify the cost: A CP3 swap is expensive upfront (usually $2,500+), but it’s a permanent fix. You also gain better fuel flow for tuning. If you plan on keeping your 6.7L past 200k miles, don't waste money on a Band-Aid like a DPK. Just rip the CP4 out and put in a pump that actually belongs in a heavy-duty diesel engine.
If you have the budget, go with the CP3 conversion and never look back. The CP4 is inherently flawed because the bucket can rotate, causing the roller to ride sideways on the cam, which creates the "glitter" everyone fears. The CP3 is a much more robust, time-tested design that doesn't have that failure mode. While a DPK saves your injectors, you're still going to be stranded on the side of the road when the CP4 dies. With a CP3, you’re buying reliability, not just damage control.
The biggest argument for the CP3 conversion isn't just saving the injectors, it's about not being stranded. If your CP4 dies with a DPK installed, your fuel system is saved, but you're still stuck on the side of the road with a dead engine, waiting for a tow. If you use your truck for hot-shotting or long-distance hauling where downtime equals lost money, the CP3 is the only real answer. If it’s just a daily driver and you can handle a tow and a $1,500 pump swap later, the DPK is a perfectly logical choice.
The Disaster Prevention Kit (DPK) is the absolute minimum insurance you should have. It doesn't stop the CP4 from failing, but it acts as a "firewall." It reroutes the crankcase fuel flow so that when the pump inevitably grinds itself into metal shavings, they get sent back to the fuel tank and caught by the filters instead of being shoved directly into your $3,000 injectors and fuel rails. It turns a $10,000 repair bill into a $2,000 pump replacement. If you don't have the $3k+ for a CP3 swap right now, install a DPK immediately.
